WesChapman
1978 Scout II terra, 345 with two drain plug oil pan and non-stock oil filter.
Haven't changed the oil in about 2 years and haven't changed the filter in about 4 years. (less than 800 miles on both) oops.
Question 1. What size are the drain plugs.the drain plug seals leak and I would like to have new ones on hand before dropping the oil.
Question 2. I had the part number written down for the oil filter but have since lost it and can't find the napa receipt. I have a wix filter on now and it's about twice as long as the stock filter. Also the threaded part of the filter housing is a larger diameter than stock. Would this be a load star filter or was there an extended capacity filter set up for light line engines?
Thanks
Thanks
