SoDakScout
Hello, here is the specs...
77 traveler with a 345. I beleive the ignition system that is in it is original..."gold box." the problem I am having is the spark plugs will not spark. If I take the center plug wire out and ground it there is a nice constant spark very visable. The coil has three wire that run to it. Only one of which has 12+v when the key is in the "run" state. When the key is in the start or "cranking over" there is still only 12+v to the same wire. The gold box has 5 wires running out of it; two to the dizzy and three to the coil. Is there anyway to ensure that the gold box is not shot? I read in one thread that there should be a wire that has 12+ while cranking and then drop to 6v at the coil. My coils only hot wire stays at 12+. Any help would be great. I will post pics when my computer stops pms'n.
