Hello everyone, im a new Scout owner trying to educate myself before I start any major projects on the toy. I need some help diagnoising a problem. Heres the lowdown.
72 sii, 4x4, 345, Dana 30front 44 rear, 20 t-case, 727trans. Stock tires and wheel size.
I have a problem with no kickdown and a lazy shift or a push type shift. I recently serviced the trans, clean inside, maybe too clean. Adjusted the bands according to procedure. Kickdown lever hooked up and adjusted properly. It does not kick down ever. The lazy shift is worse from 2nd to 3rd and it shifts through all gears under 25mph. Adjusting the kickdown rod length seems to have no effect on shift points. Unfortunatly I don't have much po history. Also it has an aftermarket B&M shifter and shift cable. Both are going back to stock asap. Sorry for the long post. Any help would be appreciated.
