Michael Mayben
I'm gonna use the distributor from the current 392. The 345 was gonna require using the 'gold box'.
Timing should be good here. I hope to remove the engine over the weekend and get to cleaning out the oil that is everywhere (to make way for new oil to be spewed everywhere at a later date)!
The 345 probably won't go in until the following.
Yep, ya gotta ton of work facing you in cleaning up the engine bay! But at least that one is original and not some botch job left over from someonelse's failed project.
And...ya need to service the tranny while it's out and accessible.
I agree about the distributor. I was expecting to find that the donor engine unit had a gold box which would only complicate the matter, that is why I asked. With the point distributor you just drop it in and go. I pulled the cap off that distributor and it's been serviced internally in recent history! If ya end up keeping this rig for more than a few months, ya can install a pertronix later on if desired.
Check yore chains and connections for the hoist twice before applying the pressure! While yore pulling the motor at yore end, I'll be pulling a 392 out of the rotten junker parts rig I bought after your t-all left here. That motor is a core only, though it is a virgin and has no po workarounds. It's an ic version, so it will be kept here for a future buildup. That rig spent the last 10 years hidden away in a filbert orchard, it was parked after the front spring hangers sheared (common on fullsize stuff) and left it a cripple.
