The kwikwire instructions appear at least to me, a little contradictory with regards to the circuits that run from the fuse panel to the alternator. On page 9, the diagram indicates that #15 red 10ga runs from the fuse panel directly to the #2 alternator post, with a jumper from there to the alt bat post. But if you look at page 10 which breaks down the variations for alternator wiring from make to make, specifically looking at the GM 3-wire example, it clearly shows #15 red terminating at the bat post with a jumper from there to the #2 alt terminal. To me this 2nd example must be the way they intended, but failed to illustrate clearly on page 9.
#14 white 16ga then runs from the fuse panel to the #1 alt terminal. This is the exciter or voltage sense wire. So where is the voltage drop taking place in this scenario? Why would it be necessary to make additional wire runs when all necessary wires appear to be present and accounted for? The only ones that aren't accounted for are the runs needed to make the stock ammeter gauge function.
