Miz Phelpsette Phase II
to mm and ihgramp,
just took the time to read this thread.
Next time, call me. I have a trailer in my driveway that needs to be used once in a while. Right now, you need a come-a-long to get stuff onto it, but it is much better than a tow bar any day.
Lyle
Gramps had a trailer too...and a 4x4 'burban ta yank it with! With air conditioning!!! But gittin' a trailer up there (and then down) wuz gonna be dicey...along with gittin' tha trailer into where it needed to be for loadout. And the winch on gramps trailer had previously been toasted. Winchman mikee wuz supposed to go along for supervising' the two old farts, but he wuz conveniently incapacitated..but we ended up gittin' hiz azz off the couch afterall!
Gramps idear was to come up with sum methodology to be able to snake these dead dawgs outta places no man has been in twenty years and growd up inna highcountry jungle. The ulterior motive wuz bring miz phelps home with anutha t-ette so it would be etched in gramps fleeting memory hole as an historical moment in time.
And...the moment wuz hysterically historical! I'm still laughin' ever time I see the pic!!
Thanks for the offer. We actually left a trailer in the driveway and made a conscious choice to use the tow bar. Because the truck had 4 doors and an 8 ft box I was concerned about it fitting and my biggest concerns was the hi way tires crossing 4 miles of rock logging road that will cut tires to ribbons in about 3miles. I have flat towed vehicles for thousands of miles with my motorhome with no problems. I just never flat towed anything down a steep mountain with no brakes and the rear vehicle on rocks (marbels). Next time I will take your trailer.
thanks for the offer. We actually left a trailer in the driveway and made a conscious choice to use the tow bar. Because the truck had 4 doors and an 8 ft box I was concerned about it fitting and my biggest concerns was the hi way tires crossing 4 miles of rock logging road that will cut tires to ribbons in about 3miles. I have flat towed vehicles for thousands of miles with my motorhome with no problems. I just never flat towed anything down a steep mountain with no brakes and the rear vehicle on rocks (marbels). Next time I will take your trailer.
Well alot of time has passed I know but I'll try to get you up to par. Six months to the day after she arrived in my yard ( last Saturday ), I took my first test drive. Brakes are still week and I had a leaky power steering line but a great ride.
Well that was in front wheel drive, I ordered a rear driveshaft today. Before I can really drive her I still need to wire the torque converter lockup and over drive switches. The interior needs alot of assembly but patchwork and heat/sound deading is done.
The engine sounds great. The only thing I did to it was a kdp or killer dowel pin. This is basically a $100 bolt that due to disign error at cummins can save your whole engine- google it.
So far the biggest headache and root of some disappointment was caused by the decision to use stock dodge intercooler and radiator. Factory coolers are much cheaper than custom and the dodge seemed to be closest to the size that might fit in this truck. Well it doesn't fit.
If I was doing it again, I would start by either planning custom cooler/radiator built on the truck or move the steering gearbox to allow room for the dodge stuff to be slid in two more inches.
The result is no factory bumper or valance. The front of truck will still look good in the end as its getting a heavy utility bumper and a ramsey 12000.
Axles and suspension
I ended up with a set from a mid 80s Chevy 3/4 ton. 14 bolt rear & hd 10 bolt front. Disks added in the rear.
To make up for the weight added up front, I had the front springs re-arched and added a couple leafs. This was about an inch too high for the rear- @ one and a half inches total. So I made some 3/4" solid steel spacers to add to the rear. I am not a fan of blocks as it is but whats 3/4 more and did it right so they shouldn't come apart. The u-bolts were then upgraded to 5/8 all around. The end ride hight is nice and still lower than any new 4x4.
The transfer case is working fine with a combination of IH and dodge linkage. IH shifter in exact original location. I also added a drive-line brake to the tail housing of the t-case to replace the original e-brake. I can even make a factory e-brake cable work if I can locate one ( mine is broken ).
Okay I'm leaving you with alot of gaps but I'll keep it coming.
well alot of time has passed I know but I'll try to get you up to par. Six months to the day after she arrived in my yard ( last Saturday ), I took my first test drive. Brakes are still week and I had a leaky power steering line but a great ride.
That is great! How about more pictures. :ciappa:
Charlieo's havin' probs with this picture thang, so here's what he's got goin' on now:
this is the fresh front axle, he'll have to fill in the deetale:
And this is the current state of affairs under tha hood:
And charlieo ain't content with just wearin' a tinfoil sombrero when drivin' the vegeoilburner, he's doin' tha whole cab in alumineeum. So that's like wearin' three condoms inna stack and sprayed down with white lithium.
Charlieo sent this out a few days ago, he's just got the new driveline schnizz from the fabdudes.
The front clip looks kinda factory don't it?
So I've been driving mrs. Phelps about half the time for a month or so. Pulls strong straight down the road. I really enjoy the stiff rear springs when pulling a trailer. The 3.73 ring and pinion is nice on the highway but I can't wait to get bigger tires ( with some tread on them ).
Yesterday I hooked up the vacuum to the h-vac, I got a couple hoses mixed up but I got defrost and floor heat.
I also installed some oem west coast mirrors that I traded the original carb for. I need to take some pics of those.
Final weight will be just over 6000 pounds.
I'm dealing with the gauges now so I can't tell exact mileage but its somewhere around 20 mpg.
My next few projects will be
windshield leak at top
tires
hitch
shocks, yes I've been driving without shocks
e-brake cable
transmission leak- tailhousing has a hole drilled in it that looks perfectly factory but everyone says it shouldn't be there- got to pull the t-case and plug it.
More to come, here's some pics.
Looking good! :thumbsup: just over 6000# is real good considering that I rolled my Scout over the scales a few days ago and it was 5200# and that was without a top and the sv is long gone.:yikes: ...I do have a full roll cage and 17" steel beadlocks with stupid heavy 37"s on them though....:icon_rolleyes:
This aint much of an update but here goes. Mrs. Phelpes needs a new home. I'm not happy about it but when compared to the well being of the fam, its no big deal.
I've spent around $15k at this point. I know I'm not getting it back.
I welcome any serious offer. If you are interested, email me
c3powen@yahoo.com
My loss is your chance to own this awesome rig with very little sweat. Any of you who have been paying attention know how much work is in this thing.
Thanks,
charlieo
this aint much of an update but here goes. Mrs. Phelpes needs a new home. I'm not happy about it but when compared to the well being of the fam, its no big deal.
c3powen@yahoo.com
Thanks,
charlieo
:icon_eek:
hate it when the economy hits you in the IH.
Good luck with the sale, its a sweet rig for sure.
