I wish that something would go right the first time, or even the second time every once in a while.... I'm in the middle of a fuel delivery issue. At this point I'm not getting enough fuel, it barely has enough to keep the engine running and the clear plastic fuel filter is close to always empty. I just put a brand new fuel pump in, and there is still no change. All the fuel filters down stream are new, I ran the pump directly off of a gas can and still no change!
at this point I really have about 2 options left:
1. The new steel hardline that is coming off of the pump is obstructed.
2. The fuel pump eccentric sheared the key/came loose/ something else....
When I pulled the old pump out, I bumped the shaft on my motor mount and had fuel spray all over me, so I know the old one was good.
I had to push the new fuel pump up to bolt it on, so I know that the fuel pump eccentric is still on. Any thoughts on this?
Moving on to some better news, I got new shocks in and began to weld on some shock mounts that I got from Jeff, but ran out of wire!
they are tacked in place for now.
