Howdy.
1972 1110 Travelall V-392 improved cooling. Motor coming out soon for rebuild or (more likely) a replacement with a remanufactured 392. Figures this would be a good time to do some other major work to the Travelall that I'd thought of to make it into a better grocery-getter and trailer-hauler.
Interested in mating a 4L80e to the new 392, and I know that IHPA sells the AA adapter kit. Just wondering what else I need to plan on doing when I swap the old 727 out for the 4L80e.
With the divorced t-case (dana 20), will I need a 4WD transmission?
Will I need a new primary drive shaft, or will the stock one work?
Transmission cross-member/mount suggestions?
Will I need an aftermarket transmission controller?
What torque converter should I go with?
Will it talk via a cable to the current factory speedo, or will I need a digital to analog converter box?
3.73 gearing in the diffs (Dana44's) and planning on 31-33" tires. Will that work?
Any other issues I should be on the lookout for?
Thanks. Any info would be appreciated!
Glenn
Glenn
