1700 Loadstar
My M/V 404 has no compression port side #3 cylinder. After making sure all the valves were closed I put some air to the dead cylinder and had air coming out the port exhaust. This leads me to believe I have a bad exhaust valve in this cylinder. Before I tear in to this beast I would like to locate parts needed such as a gasket set and valves.
Searching the web I found Felpro HS8475PT is the gasket set I believe I will need but of course my local parts store can not locate it. Anyone know of a good parts source that might have a gasket set and new valves. I believe ebay has the valves if I have to go that route.
Any input on my situation and if I missed something in my diagnosis would be appreciated. All other cylinders are 115-125 psi and the truck is running low on power due to this bad cylinder.
I
I
