crazygunnison
Okay, so I have a 1980 345 with about 100k on it. Fresh re-build heads with all new gaskets on the motor except the rear main which leaks a little. Starts great, runs smooth. Oil pressure is at about half way on the gauge while she's warming up.(do I trust the gauge?!) then when it reaches operating temp. The needle falls quickly to below the lowest line on the gauge. Sounds like the top end starts to lose oil and the valves and rockers start clacking a little. I am running fresh 10w-30. Also I should add that my Scout has been running on the hot side and I am working on a cooling problem momentarily, but I don't let her overheat. Worn oil pump? Rings? Help! Thanks guys. (just realized I should have posted this under engine tech most likely, but can't figure out how to move it, sorry)
