IC 392 Stroker Motor Advice UT Results
Cometic HG are multi layer steel MLS.
On a well built 355 sbc, 30 psi 15 psi above ambient on 8.4 CR. Stripped Moonyham roots blower. 34deg locked out timing. 100LL avc gas or 104 leaded racing fuel. nice and fat wot was very happy.
Without knock sensors you’ll be rattling that engine and pushing head gaskets out.
built enough to know the ins and outs of CR
Regarding CR- I know this no modern engine, but can it not be tuned as such to prevent detonation, and run premium gas, at something better than 8:1? Am I rolling the dice at say, 9:1CR with forced induction? I had planned on running an engine management system with FI, (probably MPFI, if I can sort it out), that controls fuel, timing, etc. On the low end, a Holley Terminator ECM with their harness, whether or not forced induction of any kind is used. E85 fuel is also plentiful here. FWIW.
Thank you!
Almost anything is possible.
When comparing what you are planning on accomplishing and comparing it to a modern high compression supercharged engine, you need to consider the millions of dollars and thousands of dynamometer hours they have invested to fine tune the heads, pistons, rods, cams, engine configuration and engine controls that allow the engines to survive the punishment.
I believe in your case EFI will be mandatory, including all of the bells and whistles needed to monitor engine conditions, working knock sensors too if availible and adaptable to your engine. Knowing what AFR is survivable at any given load, boost level and inlet air temperature.
Do whatever you plan to do carefully. Sneak up on all variables, starting with cold plugs checked every pull for a while, boost, fat initial fuel mixtures (AFR) like 11-1 under boost, bigger than normal timing retard per pound.
We ran a 2500 hp 540 inch all aluminum BBC running over 12-1 CR in a funny car for many years. 30 pounds of blower, mechanical fuel injection on methanol, port and hat injection. Even after hundreds of successful passes, every pass we ran the valve clearance for changes, and inspected the plugs. Made minute changes to the pill size (main calibration fuel bypass) for air temperature, plug readings, and valve clearance changes. Every season the bearings were checked.
I know this is a different world then you are in but it just demonstrates how important engine management is.
Very cool example.
Thank you for the advice.
I've been carefully planning this for a long time. Studying the information that's out there.
I had figured on a NA engine until Jim made his comments.
I think I'll wait till the porter gets done with the heads, have them flowed, and compare to the data of work by others that's out there, then decide on whether or not to use forced induction, then decide on CR accordingly.
Honestly, I'm not interested in trying to package any supercharger of any kind, nor turbo(s) under the hood, at this point, but would if there's a compelling reason to do so, like insurmountable poor flowing numbers from the heads.
I run a beefed up 700r4, I'm not interested in anymore internal upgrades or swapping it, either.
I may stick with NA.
I don't NEED the power, but it sure would be fun for a minute or more..
I spoke to Jim this morning. Legend!
He suggested stay away from dreams of a large displacement motor, and focus on moving more air through it. I.e., supercharger.
He suggested a minimum wall thickness of .110". More than that, and you'll get into overheating issues.
He gave a few key details of one 392 build he did, which I believe is Robert Searles' motor.
1. IC392
2. SB400 stock bore pistons @4.125"
3. Dodge slant six rods.
4. Remove as much rotating mass as you can. They realized 20lbs removed! Much of it from going to a forged aluminum piston and removing the bob weights from the connecting rods.
5. Bush the small end of the rods for a BBC wrist pin.
6. Offset grind the crank. The realized a displacement of 427ci.
As for heads, he mentioned MPG Head Service and their CNC porting program for IH heads.
He did say years ago he had the chance to talk to the IH factory engine designer, and that the designer agreed they were raspy motors. The designer said the best numbers they ever saw, wee from putting 304SV head bowls in 392 heads, among other things. These were the heads used on the factory backed Baja racers. That's pretty extreme and sweet at the same time.
I'll call him again soon, and pick his brain.
Thank you Zaed!
Are these his recommended specs for a supercharger-friendly engine? And is/are there any particular shop or shops in the U.S. who are a good choice for building up such an engine and/or installing a supercharger on such an engine (under an oem hood)?
I wouldn't say that.
His point about supercharging was that there was more to gain from supercharging, then anything else.
As far as builders, you just have to search. IHPA might do it. I don't know.
I used local enthusiast clubs to fined a machinist. They are managing the bulk of the work of the motor.
You can get on binder planet, and search posts by cycomick. He did a supercharged 345 using an Eaton m90 and multiport fuel injection. Years ago.
Best of luck!
Some bench racing cam selection results included.
Not bad for an old ag water pump cornfield motor.
CID is around 440.
Compression 10:1.
2" long tube headers.
411HP/ 560TQ NA. Absolute torque monster😁.
Steady climb from idle to 4500rpm, then dumps after that like a brick.
I want it to climb to at least 5250, but like everyone else, limited by the heads.
With 7PSI of boost, this brings me to my goal of 600HP or better. 10PSI max puts me near 700HP.
Here's the cam card for the motor. Regrind of an OEM. See how it does.
Lift numbers will increase from higher ratio rockers.
This is one option by Delta Cam in Tacoma, WA.
Another one in the works from Camcraft.
Waiting for parts to finish being coated.
Short block machining is done.
Head work is complete. Just waiting for new rockers to show up to assemble.
Final displacement is 440cid. 10.1CR.
Thank you. Going to be rebuilding mine soon. Waiting to see how yours turns out. What cam did you go with? You get the heads to flow enough? you can message me if its easier. Thank You Roger
