Assume this is the front axle of a Scout 4x4? Would help to know if it is disc or drum brake equipped. Regardless, there shouldn't be any need for pullers and bfh's. You've got the allen head screws retaining the hub dial/clutch assy. Behind that is a snap ring around the axle shaft. Then the hex had bolts for the lock hub body. Then the lock washer and large lock nut, followed by the pre-load nut and keyed thrust washer. If the rig has disk brakes, the caliper must be disengaged and set aside carefully to avoid rupturing the flex hose. Now the rotor is free to be slid off the wheel hub. The wheel hub is retained by six nuts in the case of a Dana 30, or 8 in the case of a Dana 44. I'm usually able to wiggle the wheel hub off by hand at this point, but in the case of a stubborn one, some gentle tapping with a non-marring deadblow May be necessary to get it moving.
