Alright. Here is some history on the dizzy and wiring issues from a previous posts on the bb. Looks like I miss-spoke about the type of dizzy I am running:
"after many hours of tracing wires, testing voltage, etc, with no luck, I finally decided to just go with a pertronix ignitor and use an old Holley points style distributor that I had from the old engine I rebuilt. I disconnected all wires to the gold box, pulled the dizzy out, lined the #8 on compression, stabbed the new dizzy with pertronix in it back in (lined up perfectly). I then ran one 12v source wire from the bulkhead connector/switch terminal directly to the + post on the coil (which I upgraded along with the pertronix to the flame thrower). Connected my red wire from the ignitor to the + post on the coil, the black wire to the - post on the coil. Made sure my #8 plug and wire were back in properly as I had to use the thumb trick to find the compression stroke, and turned the key to run position and tested 12.9 v at the coil +."
engine cranks but doesn't fire until key is let off? - binder bulletin forums For the full story.
I have also attached a few pics of the dizzy with the #8 wire marked with chalk and an inside shot of the petronix. I remember doing my research to make sure I had the right petronix for my application, but that doesn't mean I got it right.
Looking forward to your thoughts. Thanks guys,
-dan
-dan
