sorry for the delay...I've been trying to determine exactly what that intake system consists of, here's my comments:
the carb in your pics is a Holley 2210c and is most likely correct (based on my research) for that engine. The numbers all jive. A very common mixer for many IH apps.
What is messin' with me is the unit under the carb. I don't have the correct parts list for that particular loadstar...but I believe what you have is an "electronic" governor unit, not at all like what would have been found on an earlier loadstar/medium duty rig. Those used a 2300g (g for governor) which is a far more complex carburetion system than what you have and must be used in conjunction with a governed distributor also as a package if you want the governor to operate. And the emissions diagram you posted plainly states 2300g! Do you think that label is original to this vehicle??
I have no experience with that electronic governor unit itself, I've only read about 'em, never seen one. It is controlled by that electronic module in the other pic you posted. That module is not a "gold box" ignition system component. So I don't know "how" to service or diagnose that unit, however, if you don't have need for a governor system, then it appears all that stuff is bolt-on and can easily be removed and have just the carb mounted to the intake like on a light line vehicle (Scout II or pickall).
As for the egr, I'd loose all that crap and install a block-off plate in place of the egr valve. Then ya run a vacuum hose direct from the ported vacuum port on the carb to the distributor vacuum can, assuming that the distributor can actually is functional..many are not at this point in time and we have re-manufactured units for replacement.
I have that exact carb on the bench now for reconditioning, it is going down to ihon and be placed in inventory there for sale/exchange. Our "carb shop" information is new and you will find details here:
http://www.forums.IHPartsAmerica.com/new-products-IH-only/3479-IH-only-north-fuel-systems-shop.html
So we could simply do an exchange...or if you want the core you have now rebuilt, then contact Jeff at the store for ordering info and he'll take care of ya and have your carb drop-shipped to me.
I'm still researching that governor unit, I knew this would come up someday, now I need to educate myself!!!
I do have a couple of 2300g carbs that need some serious luv. But they can be turned into nice carbs no doubt, done many of those...just takes alot more time to deal with those than a typical 2300 rebuild. But if this truck is gonna be an "occasional" use rig and not pressed into commercial service, I'd forgo all the governor stuff and just learn how to drive it with an educated foot and gear shift arm!
Also, the distributor I see in the pics is not a Holley governor unit, pics of a governor Holley distributor May be found in post #3 in this thread:
http://www.forums.IHPartsAmerica.com/ignition-tech/642-ihc-vehicle-distributor-identification.html
