Hey. New to this site but seems like this might be the place to be. I looked at the thread about "22** carbs" and thought I had mine pegged for a 2245, but there are a few differences and I need some help so I can order the correct rebuild kit.
Background: not a mechanic, but learn quick. I bought this 75 Scout from a buddy who took it in trade for some work. Thought it had a sticking valve. Later, after I had the heads reworked, new cam, lifters, fuel pump, distributor, points, plugs, wires, and coil, it still stumbles a little on accelleration. ( I did allthis myself except for the head work). I had some pretty significant backfires after I put it all together, and want to rule out carb problems now. The first start of the day always requires a small shot of ether. After that, it starts fine the rest of the day no matter how long it sits.
Problems:
1. The port on the side where I think I am supposed to hook my vaccum advance has no vaccum. After reading the other thread it looks like it has the wrong gasket and this port is open. See pic
2. Has no port on the upper left front like the ones in the other thread. I believe this was called the bowl vent?
3. Has the hic (?) under the plate on the back
4. Is there a napa part number for a rebuild kit for this thing?
Thanks in advance for any help. Look forward to rebuilding this Scout with help from this site.
Problems:
