Hi guys. This May not be the most popular thing to do to a Travelall as it seems most lift them but I want to lower mine. My question is on this year in 2 wd (it is the smaller 5x4.5" wheel bolt pattern if that helps) I guess it has the independent front end right? Not a straight axle like the older ones? The truck is not here for me to look at so I can't tell if it has traditional front coil springs and shocks or what. The rears are leafs so I imagine I can have them de arched or just do lowering blocks pretty easily back there. I also remember reading the front has a torsion bar set up. The only experience I have with one of those is in an old 61 dodge, which I was just able to crank on a large center bolt to lower the front end. Any info would be great as I'm completely ignorant on IH's! Thank you!!
