"one of the big "urban myths" which go around regarding ihc-produced vehicles is that "all sv distributors interchange". While it's true that the distributor lower body/drive design does allow any IH-app distributor to be installed in any sv engine, the rest of that statement is bogus." -mayben
so I'm trying to get my 76 running well enough to call itself a dependable daily driver. The distributor I have in it now is not original, I believe it is a points dizzy but haven't verified the specific model. I was curious as to what distributor would be best(budget, performance, and reliability) fit for my application. It has a 345 with a 0-7448 carb, tf727 living around 3000 ft. And where it can get both very cold and very hot. I've heard that the points dizzys aren't exactly the best to say the least.
I'm looking for help in choosing a better distributor or if I should just go through my current one. It does like to stumble around idle/acceleration when the engine hasn't warmed up entirely but after warming up, runs very well. The carb has around 500 miles on it since I bought it new from Jeff.
I am going to be buying a service manual(also from Jeff), would that have the procedure for adjusting points and dwell and such a distributor or no?
your original setup would have been a Holley electronic ignition with remote control module, better know as the Holley gold box. I think the first thing you ought to do is make proper identification of your current distributor. There are quite a few pictures in the various threads under ignition tech that could help you, or it might be faster to supply a couple well lit, well focused pics of the thing with both the cap on and off.
