the "gold box" is the ignition module but only with a Holley dizzy.
Thanks Robert. I guess that explains why I can't seem to find it!
the resistor element on your rotor is not is not a consumable device in normal use. It can become faulty but not from normal use.
However.... The use of a large plug gap can increase the secondary firing voltage to the point that the cap, rotor and wires can no longer satisfactorily prevent shorts to ground and carbon tracking. Delco's sad attempt at the high energy ignition (hei) used a cap mounted coil and a very large cap and rotor to improve the insulating conditions, however as the ignition system aged and the inside on the cap became dirty and contaminated the insulating properties were compromised till the spark would track to ground and complete ignition system failiure...
While voltage increases will increase firing wattage(power) no performance ignition will utilize only voltage to achieve superior firing. Increased current is a better way to this end hence a smaller gap like .045-.035 max and lower firing voltage. A msd will work better at .035 pug gap.
Hmmm... Thank you for that information. I'm a little unclear though whether you are advising me to regap the existing plugs, discard the existing plugs and get new ones, or just learn from this experience and set the next batch at < .045.
