jeff campbell
Active member
Can I mate a d-30 inner right front( pass side ) to a d-44 outer stub shaft ? Thx-Jeff
can I mate a d-30 inner right front( pass side ) to a d-44 outer stub shaft ? Thx-Jeff
on a Scout II yes -- the ujoint is the same size for both, 760x.
On earlier models (all brands not just IH) maybe or no - the early Dana (both Dana 30 and Dana 44) stuff ran 260x ujoints which have a smaller cap diameter - so if you have one of those you are out of luck.
are sure chris? Although IH had all sorts of combinations all I have seen in a Scout II Dana 30(disc or drum) has been 260 ujoints. The sii 44 as chris pointed out is definitely a 297 or 760 which is a bigger ujoint.
chris,are the d-30 disc shafts the same as the drum brake shaft's ? Tia ! Jeff![]()
thanks, Jeff. But will the axles interchange,even though they have different u-joint's ? Can you use a drum brake axle shaft in a disc brake axle ? Tia !
