Okay. This is sounding more like a fuel delivery problem more than anything else. Are you running any fuel filters before the carb?
It does have a fuel filter, I did check the throttle and there is a nice stream of fuel that is pumped into each barrel of the carb.okay. This is sounding more like a fuel delivery problem more than anything else. Are you running any fuel filters before the carb?
if the #8 cyl is getting a good spark to the plug, hook a timing light to the #8 plug wire and verify the timing is set to about 5* before tdc at idle speed.
I am having issues as well with my 69 1200d running bad. I changed the plugs and wires, and it still runs bad. It will stay idling if I have the choke pulled half-way otherwise it will die when trying to take off from a stand still. Any help would be appreciated.
