Michael Mayben
Beginning with some possibly later m/y 1977 Scout II rigs with a 345 and on through eop, the carter "thermoquad" 4v carb was standard issue.
The same carburetor series was also used on some fullsize rigs equipped with the 392 motor for m/y 1974 and 1975 production.
These units are generically refered to as a "spread bore" throttle body design, a description of the design which incorporates relatively small diameter primary throttle bores, with much larger secondary throttle bores.
The mounting fastener configuration for this carb series is also not interchangeable with the Holley modular carbs we refer to as "square bore" throttle bodies.
It is possible in many cases to use a suitable adapter to convert one manifold design to another so that these various carbs can be interchanged. But performance-wise, an adapter is not considered to be the best solution, and it also adds to the induction system height which May create a hood interference issue on many vehicles.
This shot shows the intake manifold side of the cast aluminum (not cast zinc) throttle body used on the thermoquad.
