I posted in the past about a rebuilt 304 I picked up that sat for 10 years and was never installed.
After installing the motor following proper break in procedure it developed a rapping noise in the #1 exhaust lifter after 3 hours run time that would not go away. After further inspection 12 of the 16 lifters were not rotating and figured that the lifters were used ones put in by the builder. I put a new clevite stock cam and sealed power lifters in and everything was fine. No ticking or rapping noises and all lifters were rotating. I've put close to a 1000 miles on the motor with no issues. Now it's making the rapping noise again. Only this time it sounds like it is coming from the #2 cylinder. It raps loud during start up for about 5 minutes. Only when the motor temp is hitting 150 degrees does it start going away. When the temp hits 180 the noise is almost non existant. You can hear a faint noise when the rpm's increase. I pulled the rocker shaft this weekend to check things out. I pulled each lifter and none were cupped. I did notice that on the #2 and #6 exhaust valves tips that the tips had a rough edge with small amounts of material that were wearing off the edges. Also #2 and #6 exhaust lifters are not rotating. Oil pressure is 50# at start up and 10# when hot. Lot's of oil flowing through the boat style rockers. The motor runs great. Steady 17" vacuum when at idle.
Getting a bit frustrated, what can be causing this issue?
