Steve Grant
I recently aquired a 1972 1210 camper special. This truck was converted to four wheel drive. The rear end is a Dana 60. The front is a Dana 60 out of a 1 ton dodge 4x4, the p.o. Swapped it in from a military truck. Non ic 392. Disc brakes in the front, drum in the rear. When I got the truck, he was saying its going to need a bigger master cylinder, because you have to pump the brakes to slow it down. It felt like to me master cylinder was shot, it would pump up, then go to the floor. The master cylinder did not look oem, I removed it and went to napa, the part number is for a 1 ton dodge truck. I bought a new master like the part that was on it, bench bled it, installed it on the truck, adjusted the rod length during that process, bled the brakes, it was still doing the same thing. I returned that master cylinder, wasn't squirting brake fluid out the front brakes anymore. I made certain I did not push the spool inside the cylinder past 1''. I got another master cylinder, for a 200 series truck. It's doing the same thing, but its squirting fluid out like it should. There were no air bubbles to be seen. Do I need a bigger master cylinder?? The front brakes are bendix, huge calipers. I would really like the get this truck up and going. No pressure build up on the brakes period.
Thank you for the help.
