I have a 69 Scout with a 345 and a bw trans. It worked great when I parked it. It sat for about 3 months and now the trans is acting up. Park seems to be reverse, reverse works, neutral works, drive acts like it wants to lock up, second is a little worse, and first locks up. I pulled the valve body and cleaned it and found two of the poppets where stuck. Freed those up, reassembled and I still have the same issues. I also checked the vacuum modulator and it holds a vacuum. There was quite a bit of black sludge in the pan and on top of the valve body, I'm assuming it was band material. I had the valve body out once before to change the shaft seal for the linkage at which time I cleaned the pan and the valve body and only put approx. 100 miles on after that. Anybody have any ideas?
