IceFyre13th
Maricopa county az emissions test failed the hc idle reading, 616 ppm on an allowed 400 ppm. Idle co was 2.58 % out of 5.0 %, a pass.
Loaded readings were 115 ppm out of 400 ppm for hc and 0.14 % out of 3.75 % for co, both a pass.
So I need to hire you to adjust my chip to fix the idle reading.
I have 60 days from today to get a retest done. Let me know what you need from me. I can send you the vehicle inspection report if you need it (there is a form on the back that has areas that are to be filled out by the repair facility or me as diy)
btw, the old chip I sent back to you, the usps decided to destroy the package and loose it. I filled out their description of item form so they can "look" for the contents of the package, but I don't hold my breath they will find it. Looks like I ow you the cost of that chip too.
Thanks.
Thanks.
