Best engine cooling fan for v-8 scout 800...
68scout
I am running the stock give blade cooling fan with aluminum radiator for n my scout and going down the road it cools just fine. But when I'm crawling around up in the hills and it's over 100° with no wind blowing through the radiator I can hear the coolant boiling in the heater core. Is there a clutch fan setup that fits the tight space between the water pump and the radiator?
You can't fit a clutch fan in a Scout 800. You shouldn't be having tremendous cooling issues. If you are, sounds like something is wrong. I would start to be concerned over 220. A fan clutch would make the cooling worse. You should check your radiator and block and flush them out good by pooping the freeze plugs out.
Why Thank you sir. My temp. Gauge does not have actual temps on it, but when it goes to the top of the range and I can hear coolant boiling in my heater core at extremely slow speed that tells me she's getting pretty hot. I have the aftermarket aluminum radiator for the v8 scout 800 and it works great when I am making some wind with forward movement. I have the five blades fan from the stock four blades unit. Would it be worth trying a six or should I try electric?
You should do like he mentioned and make sure the block is clean. Flush it with a Chemical flush and see if it gets better. If not like he mentioned pull the core plugs out of the sides of the block and get in there with a pressure washer. (Dan Hayes at binder boneyard did a podcast all about this)
Make sure you have a Robertshaw thermostat installed. Not a gnereic parts store thermostat.
Run a 13 lb rad cap.
Make sure you have a fan shroud.
Yep, got the shroud, probably a cheap parts store thermostat. The block hasn't been boiled since it was rebuilt in the nineties. Thanks for the things to try.
Then thermostat would be my first bet. If the blocks been cleaned out before its likely fine then. Dan mentioned the factory likely didn't clean them very well and casting sand etc stayed in them.
I know Scott Stroud had posted a couple different modern fan options over at binder planet. If yours is 18" fan may work.
Had a 345 like that too. When it was out for a refresh the core plugs were pulled and there was an astounding amount of crap it. Placed it nose up on a tire and flushed from the front to back, never a problem after that.
