ronmc1954
Well I found another 345 combo since the heads I wanted rebuilt turned into boat anchors so to speak.(cost to much)
now I have done some testing on this new (out of a 79)345, I was told it only had 60,000 mi on it and that the motor was in real good shape.
So I got it home pulled off ps & alt and valve covers and pulled dizzy. Primed the oil gallery and it seem to oil just fine.
Then I pulled plugs for a compression test here's the results:
cold crank (dry cylinders I would guess): 90psi to 120psi
I then shot some oil in the cylinders and tested again: 145psi to 155psi again cold engine.
I'm thinking that's pretty good, right?
Now the other question this motor has a 4bbl manifold on it. Here is a pic:
Not having much expirience with 4bbl's what am I looking at here? Spreadbore or squarebore?
If I were to consider using this intake what carb would you recommend?
The tranny supposidly only has 2000mi on an overhaul, this combo was last run 2 years ago and stored inside since then. I tink it's a pretty good find.
Thanks
ron
Thanks
ron
