AFI Temp Sensor Installation
The temperature sensor supplied with the afi kit is way too big for the hole used for the stock sensor.
How should the afi sensor be installed?
If you remove the stock sensor, how will your stock gauge work?
The cts can be installed in the hole on the other side of the thermostat housing or in one of the water passage holes near the back of the intake where the vacuum temp switches normally go.
