Bob Prohaska
'72 Scout II, 4x4, v345, ps, pb, at, ac, stock.
[I can't find a thread anywhere on replacing stock engine mounts for a v345. All my search attempts
drew either a blank or irrelevant hits. If this question has been answered already pointers much appreciated!]
It looks like the engine is sitting a bit low, based on the centering of the fan in the shroud. Since the radiator
is out, it seemed like a good idea to try shimming the engine mounts to give a bit more clearance, say, an
extra eighth or quarter inch. However, the studs on the isolators are a good inch and a half long, top and
bottom. That implies I'll have to lift the engine at least three inches to get them out, or maybe two inches
to find space enough to fit washers over the lower studs.
I tried lifting the front of the engine using a jack under the front well of the oil pan, but it seemed to take
a lot of force and I was worried about either denting the pan or allowing the engine to twist the rear
mount, which I don't want to damage, even if there's enough vertical clearance in places I can't see.
I'll have to lift with a jack, no hoist in my garage.
For the moment it's tempting to put the radiator back and leave well enough alone. If there's a better-
informed approach I'd be grateful for guidance. It looks like the fan will scuff the shroud eventually.
Thanks for reading,
bob prohaska
Thanks for reading,
bob prohaska
