pretty sure, its just 2 wires. One to the coil(side that feeds the distibutor) and the other is a ground. When I set it at double on the v8 setting that would be at 1100 rpm on the 8 cyl scale, if I am doing this correct? If thats right it sounds like its at 1100 rpms and not 550 rpm's. One thing I was curious about was the fact that this particular 4 cyl is in all actuality 1/2 of a 392 v8, so do you still time it at a 4 cyl setting or could it be the 8?
No had not looked at the fuel pressure
just had a thought, I wonder if I am not letting the Scout get hot enough before I am setting my carb mix and idle speed. I havent been taking it down the road, just letting it sit and idle for awhile until the temp guage is at normal operating temp
