wiggins
I have a 78' Scout with the slant 4. It has 52,xxx original miles and cranks and runs great. The problem is when I kill it. It refuses to quit, but not in a good way. It diesels out once I ve turned the ignition off until it chokes it self out. I figured I had a timming issue but it is set at tdc, perfect.(unless I am timing wrong? Off #1 and plugging the vac adv line?) I have adjusted the carb out and nothing worked so I determined that it must be the carb. I let a local shop rebuild the carb and they said the carb was slightly slugged w old gas but not bad. They rebuilt it but the problem still exist. It does not always deisel now, but if it does not, it sounds like shotgun coming out the tailpipe(backfire). I am wondering if it is still the carb, accelerater pump ect..?, or something else?
