Jeffsarasota
Afternoon everybody. 1978 Scout II. I need to remove all the sheet-metal and radiator support from the front end? That way I have better access to the motor and can detail the engine compartment is there any trick to this? Can I remove the front quarters inner and outer at the same time? Does the radiator support just unbolt once the quarters and front grill assembly are removed? Any suggestions are appreciated
