Unfortunately I did not know that was going to be an issue when it came to installing the Borgeson Joints. I thought it would have been a simple bolt on application. The power steering gear was rebuilt prior to re-installing the steering column and the Borgeson Joints. From the picture I included on the last post. Did I leave enough of a nub? Also I loosened the lock nut to adjust the set screw. Do I need to have the steering gear rebuilt/re-adjusted. Should I purchase a replacement steering gear from a reputable source? What would be your suggestion? Thank you for the advise.
I've recently retired and I'm looking forward to getting this on the road. After the steering is 100% satisfactory its off to get the AC system charged then minor body work finished and painted.
Did you install the springs after or before the Cut and Turn?
Put an angle finder on your steer arms and see what the actual caster is at ride height.
at 50 MPH your at about 2,500 RPMHi Zaedster, thanks for the reply. I did have the steering gear rebuilt. Was it the best shop in the LA area, I'm not sure. They did mark the setting with a white marker and I can adjust it back. To me the steering wheel had to much play and seems to be better now. When I installed the Borgeson Joints I did have an issue making it fit with that nub sticking out. I can't remember if I discussed this on the phone with IHPA or thru the forum. I was advised to cut that knub off to make the joints fit. There's a picture attached of my cut on the nub. On smooth roads it drives great one hand on the wheel. It's only the bumpy roads that make me uncomfortable.
So far, over time I've only driven the Scout up to 50 miles per hour. Most of the 250 miles of it have been up to 35 mph. I would like to install a tach on it so I don't push it to hard. I'm not sure what the RPMs on the engine are with my set up. I'm running 33x10.5x15 tires with 4.10 gears, TF 727 thru a Dana 20.
It could be very well that I need a new steering gear.
Very true,I would personally send the box out, maybe to PSC and specify your application, and stiffness you like in the steering feel. I would start there.
Also, it is worth noting tires have a significant affect on road handling. Maybe try out a different set of tires also.
I know this is a post from last year but I’m wondering if you have any advice on how to get started popping out the sliders? PO replaced the outer frame seals but let the super crusty sliding glass rubber so I’m having to replace that only (ideally) Any advice would be greatly appreciatedA few weeks ago I got my travel top side sliding windows installed. I had to get creative to install the windows as I had no help. It was actually easy to install by myself. I soaked a thin roap into a soapy water solution. I used a gasket caulking tip to push the rope into the window gasket channel easily as I ran the nozzle and rope around the channel completely. I tied knotts in both ends of the rope where they met. I brushed on a soapy solution around the window gasket and pushed the window in place in the travel top and held with one hand. With the other hand reaching inside the passenger door to grab one piece of the soapy rope, I would pull the rope toward me to get the window gasket to climb over the ridge. Once I had about a third or more of the gasket over the ridge it was safe enough to take my hand off the window as it was not going to fall out. Then I would get in the interior of the scout and finish pulling the soapy rope around the rest of the window channel. After getting the gasket over the ridge, portions of the gasket would not lay flat on top of the ridge. If the gasket is not completely flat going around the interior of the window the gasket is not 100% seated over the ridge. Parts of it would be partly twisted exspecially around the corners. I used some plastic trim tools from HF to manipulate the gasket to lay flat over the complete channel . I did the same on the other side. I hope these tips help someone else on a travel top window install. I could not find any good information on this install in forums that I searched. Thanks for following the build.
Thanks for the feedback. First rodeo with anything like this. Give me anything mechanical but this seems like something you do by “feel”I installed my sliders into the groove of the window seal using a soapy rope and some plastic interior trim removal tools that I bought at Harbor Freight. I would start at or near a corner on the outside and get the edge of a plastic trim tool and wedge it between the seal and glass and try to pry up under the window frame to pop it out of the seal. It may be helpful to have someone in the cab pushing slight pressure on the corner of the glass your working on to pop out.
