GingerCowboy
So, I have pulled the tranny, didn't want to, bu didn't think I had a choice, now I see that I May have been able to fix this with the tranny still in place and just pulling the adapter off. The issue was/still is, that there is 3/8" slop in the rear output shaft (in and out, not up and down). I think I understand that there should be some sort of "retainer" between the bearing on the output shaft , between the adapter housing and the double gear that enters the transfer case. Mine had none, and the transfer case was full of atf. This wasnt the first indicator though, the truck, when throttled down, and released quickly, would rattle somewhere between neutral and 2h. The shaft was pulling the double gear out of the transfer case far enough to disengage it and let it rattle inside the transfer case. I would like to solve this issue but have no idea which rebuild kit to buy, or if it is repairable... Any suggestions?
Thank you,
loren
Thank you,
loren
