smog checks are lame
ive been a master tech for toyota and mercedes but recently started working for tesla... Sooo much easier. Before you dump a ton of money into the honda lets take a look at it and see if its even worth it.
Tesla, the all electric car company? Cool! Is that the one on santa monica blvd?
How is the company doing? What limited info I've read about the company is that its still very shakey and if it wasn't for a regular infusion of government incentive money, the company would not stay in business. What models are in actual production now? Too bad they don't make a cheaper model as I so like the concept. I've driven the ev1 and it was fast! Too bad GM bought the rights to the battery technology under the pretense of using it in their delco battery division then selling it to texaco, who, of course, buried it. It's taken years to develop another battery technology, and so far its only the expensive lithium ion.
I spent a ton of money on smogging my car. What a waste. It has the expensive catalytic converter that's built into the exhaust manifold rather than added to the tail pipe like a muffler. Ever price a new catalytic exhaust manifold - big $$. But its still cheaper than buying another car.
I've been doing a lot of research on upgrades for my truck. And I've bought a few parts to help that research along.
Also acquired most of the parts to convert to power steering.
http://forums.IHPartsAmerica.com/attachments/axle-tech-questions/20968d1377927344-c120-vs-c1500-axles-conversion-set_7a-110.jpg[/img ]
And finally sourced the parts to convert from single circuit brakes to dual circuit brakes. I've driven trucks for years with single circuit brakes with no problems, but the brakes in this truck just plain scare me - broken brake drum, missing rear parking brake links, deep gashes in the new rubber flex lines, and they rub against the knuckle every time the wheels are turned, the pedal is hard but if traveling over 35 mph this truck just will not stop standing on the brake pedal. I know, all things that can be fixed, but if fixing this stuff, I'd rather be putting the time into something more substantial - like the brakes in the axles above rather than my little knuckle d44.
The dual circuit brake parts came as just a big box of disconnected brackets, pins and levers. And having never seen how it came apart, it was a fun puzzle to put back together, the kind of truck work I prefer to do. I know I'll need to get new master brake and clutch cylinders and power booster, but this was just a test assembly to see how it all goes together, and if any parts were missing. Only got one pedal spring - I think it goes on the clutch pedal. Shouldn't there be a a spring on the brake pedal too, or is it unnecessary because it has the vacuum booster?
So I'll be going from this first pic to the second pic:
[img]http://forums.IHPartsAmerica.com/attachments/axle-tech-questions/20971d1377927608-c120-vs-c1500-axles-conversion-set_7a-208.jpg
http://forums.IHPartsAmerica.com/attachments/readers-rides/21296d1381468251-62-crew-cab-4x4-restoration-project-set_7a-424.jpg[/img ]
[img]http://forums.IHPartsAmerica.com/attachments/readers-rides/21297d1381468251-62-crew-cab-4x4-restoration-project-set_7a-425.jpg
http://forums.IHPartsAmerica.com/attachments/readers-rides/21298d1381468251-62-crew-cab-4x4-restoration-project-set_7a-426.jpg[/img ]
Now if the weather holds out, and other things don't distract me, hopefully I can get back to working on my truck. I'll do a detailed write up on all these things when I get to them.
Steve
