sdowney717
I have twin IH nonic 392 palmer marinized engines with rochestor 4g carbs. One is reverse rotation.
Does cranking speed affect starting?
One of the engines is hard to start.
The other one starts fine.
Also one engine I noticed is smoking when it runs with a slightly bluish color. Not huge black clouds more of a hazy look to it.
That engine also has solid lifters so you have to manually set the clearance, other one is hydraulic.
The one that smokes is hard to start.
when it runs it runs fine. It is overfilled by a quart right now. The boat has sat for a number of years being worked on for issues unrelated to the engines. I just started them today and noticed this hard to start and smoky exhaust.
That engine has a history of flooding out, probably running Rich due to carb fuel overpressure and too high float level. I fixed that today.
It would not start and I noticed a lot of fuel down the carb throat. When I pulled the plugs they were oil-gas wet with some sludge on several. I cleaned them and put them in and managed to start it eventually. Oil pressure is a good 40psi on both engines at warm idle and does not change with increased rpm.
This hard starting engine also has a huge suction in the crankcase venting system. If you remove the oil fill plug and put you hand over this while running you get a good suction vacuum effect so strong it will whistle the oil dip stick tube of the dipstick is slightly lifted up. I assume this means the lower end is sealing very well? The other engine does not do this. I suppose a huge suction might pull oil past the intake valves and make it burn oil?
Both engines have 2 pcv valves one on each valve cover which feed into 2 separate ports on the intake manifold.
Would a lot of flooding loosen up a lot of carbon and cause a lot of smoking and hard starting? I ran the engine for about 15 minutes and the smoking did not really get much better.
So looking for some ideas on the hard starting and smokey looking exhaust.
Palmer turns these motors around so the front of the engine is the pto point and the flywheel is facing towards the front of the boat.
