I hope it goes well for you. Back when I was a teen with zero mechanical experience, my dad and I hired one of his co-workers who was supposedly a good mechanic...to swap a 351 Cleveland and FMX auto trans, both from a '72 Ranchero, into my '57 F-100 pickup. The FMX trans is as I understand, is quite similar to the Borg Warner unit you have. Anyhoo, this guy lets my dad know one day at work that he has the engine and trans in the pickup and that it's ready for us to come and get. When we get there a few days later to take it home, he informs us that at first the engine refused to turn over with the starter, but that he kept trying and trying and finally it all of a sudden began cranking preceded by either a bang or a pop sound. That was wierd! Then he said that he tried putting it in gear but it wouldn't move in either direction. He attributed that to not having enough ATF to bring the level right and perhaps some air trapped in the system. Niether my dad nor I thought too much of it at the time and accepted his explanation as plausible. We fired up the engine and ran it for awhile. It sounded good, so we paid him and towed the truck home. We checked the fluid level, and in fact it was a bit low, so we added fluid to the proper level. The trans still would not engage any gear position. We ran the engine for some time trying to get the trans to go into gear, checking and re-checking the fluid level to no avail. At this point, both my dad and I became very concerned. We decided it was time to drop the trans to see if we could determine what the issue might be. Once the unit was down and out, the issue became instantly apparent even to us greenhorns. The input shaft was completely severed and the broken surfaces were worn partially smooth from all the engine running after the initial breakage. We then dropped the fluid pan and found it to be full of metal chunks and particulate. We asked of a trusted friend with experience what could have caused that and his reply was quite simply not having the converter properly seated when the engine and trans were mated, followed by trying and eventually succeeding in starting the engine. So we scrapped that trans and had the same trusted friend source a good, used C-6 for us, which we successfully installed ourselves. I can remember my dad being very nervous about making sure he got the converter fully seated, but he nailed it.
