wlcantrell
1978 304, flat top heads, original IH not touched internally.
No California emissions
prestolite electronic dist
90k miles on the odometer
kids have played with it for the past five years for fun and school. Check the oil, yea sure Dad!. Last spring the kids took the Scout to play in mud puddles and the Scout got a good drink of water in the intake.
A few months ago, I noticed an odd vibration,not noisy, when accelerating (it passed emissions with this problem). Happens under load and not. So, since the engine was inches deep in grime, I decided to pull it and see what was what:
replaced gaskets and freeze plugs. Freeze plugs were weeping, so May have had a problem with cyl walls overheating. Did not see that the engine itself overheated.
120 + compression in all cyl with all plugs removed.
Replaced plugs (gapped 35), coil, cap, rotor and plug harness. Checked the harness firing order like a dozen times...
"visually" inspected the valve train using the starter to turn the motor, and each valve seemed to articulate as it should.
No valve train noise.
Oil pan was free from shavings and chunks of stuff. There were a couple of aluminum shavings, kinda looked like shim stuff, but could not identify where it would have come from.
Stuffed the engine back in, and still had the same vibration. After a couple of days, pulled the plugs and #6 looked dead, no tan color on the tip. Replaced the plug and ran for a couple hundred miles. Pulled #6 again a little bit of tan, but not as much as the others. Ensured that #6 was getting spark. Oww! Yep it is.
So today I pulled the rocker assembly on that side to see if I had a bent push rod or collapsed lifter. Lifters that I pulled are slightly concave but are not collapsed. All of the rods are straight, don't see any problems with the rockers.
Whadda think? My buddies are shouting that I probably have shot the cam or a cam bearing.
