With those idle mixture needles, do you remember installing or can you now see a small, cork o-ring on each one as erik mentioned? Its very important that those little do-dads are in place.
The choke plate tension adjusts by rotating the black thermal housing one direction or the other. There are three set screws in a triangular pattern that lock the thermal in position. Loosen, but do not remove each screw. There are rotation arrows on the face of the thermal indicating either lean or Rich. Rotate the knob in the Rich direction to allow the choke plate to close up more. There are also a series of index notches on the top surface of the thermal with an arrow pointer. You really shouldn't need to go more than one notch beyond the center line in either the Rich or lean direction to be set up pretty well. This is all providing that there isn't any alignment problem with the choke plate that would prevent it from closing.
The problem I mentioned with the linkage isn't so much with the pivot bracket itself. It looked fine. The problem is with the flat bar with the slot cut out in the center and the tang for the small spring on one side. The tang and spring should be facing towards the center of the engine rather than out towards the fender. But again, this has nothing to do with your engine not being able to idle.
