Re: Wow
that gasket looks like fungified swiss cheese and that throttle bottle, wow. I know my Travelall sat for awhile, but at least it wasn't sitting underwater.
So I have a few things on order (including locktite blue), when they come in I can start to rebuild.
What about a "spacer" where the felpro carburetor gasket goes. I have heard of some people using an additional spacer there to "make tuning easier"? I am guessing this means that the heat from the engine, causes some expansion of the carburetor metals, and it can throw off some of the tuning you did when it was "cold". This is all an assumption on my part (and I know the inherent risks of assuming!).
So, could you educate me on this?
Craig
I use various forms and thicknesses of "spacers" when I can on any engine/carb/manifold combo. However, that fel-pro "heat dam" gasket you found was/is used as an oem solution to fuel "percolation" which happens under some conditions when the engine is shut down and the radiated heat from the manifold (most especially the exhaust "heat" crossover) causes the fuel in the bowl(s) to "boil" and expand past the vent and needle/seat and run down into the intake plenum. And...that gasket, though used in many oem apps over the years, is a part originally developed for the IH 266/304 engine using the same Holley 2300 you have! Most all other oem manufacturers used similar products over the years including some very elaborate steel or aluminum sheet "heat baffles".
The "tuning" thing you mention is actually related to the expansion/contraction of the die cast zinc carb components vs. The aluminum throttle body. That is what causes the screws to loosen over time resulting in carb performance deterioration...and why we rebuild 'em every two years as part of "maintenance" these days! But tightening the shit out of the screws that are treated with loctite also will prevent that!
In a "short-term" engine shut down, that manifests itself as a "flooded" condition momentarily. If allowed to say sit overnight, then the bowl(s) will have to be "re-filled" by the fuel pump during cold engine crankover and will take longer for the engine to start, that kinda puts excessive strain on the starter and battery over time.
Percolation became much more of a problem with the advent of elevated engine cooling system temps used by many manufacturers for "emissions" packages. Fortunately, IH never did that bit of smoke and mirrors that really affected drivability!
You could easily use a 1/2" aluminum, or phenolic, (or delrin) spacer under your carb and retain the heat dam gasket!!! I do that all the time! And...on some of the earliest versions of the sv motor intake manifolds, when ya install a popular "aftermarket" replacement carburetor, the throttle arm on those units won't clear the oem manifold, so a spacer is imperative to lift the carb off the manifold.
Some of the most popular carb spacers of all time were machined from mahogany! Wood is an outstanding product for this but really oldskool! Many dirt trackers still use only wood spacers!
But...for even mixture distribution in your application, ya definitely wanna use a spacer of the "two hole" design, not the open plenum type! Even as old as your manifold is, it's still a somewhat "advanced" (especially for that period in time) dual plane design.
In your case, one of the limiting factors is that "rod" type throttle linkage. Too much spacer and you will have to mod the rod system, possibly adding in a "z" segment to allow a proper angle of pull.
With your t'all (and pickups), there is plenty room under the hood for some carb lift...but on a Scout II there is virtually no room for that unless various air cleaner workarounds are employed.
This pic shows the current "heat armor" solution I'm currently using on my 392 witha 4v Holley carb. That is a 1/2" four hole spacer (correct hole diameter match for both the Holley 80457 carb and the rpt intake manifold), along with a Holley-supply version of that heat dam gasket. This one is a two-ply material fabbed from some kinda resin-impregnated vegetable fiber material, extremely rigid like fiberglass. The extensions on the front and rear of the heat dam "protect" the dual fuel bowls used on the Holley carb, the cutouts allow use of a 50cc accel pump on the primary bowl if desired (I do not use that!) and provide clearance for use with some applications of a Holley carb when used with popular aftermarket manifolds from weiand, edelbrock, offy, etc.
In addition to the heat dam stuff, I run "lpg" (propane application) intake manifold gaskets on this ic 392. Those gaskets block the exhaust crossover passages which further reduces/eliminates any potential for percolation and ensures maximum mixture density is available to the combustion chambers. This is a performance-oriented motor not a smogmotor! But in it's current incarnation, it produces hc/co numbers well under the smog specs for that era (circa 1973). More info about that here:
http://www.forums.IHPartsAmerica.com/carb-tech/76-beer-can-maneefol-guapo.html
After 20k+ miles pulling a 6500+lb. Trailer I couldn't be more happy with overall drivability at this point. Only thing that would make shit better is for the fuckin' gummint to git us out of the fuckin' ethanol bizz and ban the use of e10! But as we now see...it's only gonna git worse (e15 and beyond??) unless we start the revolution now!
