1968 travall 2wd, 304, 3 on the tree
68 travelall
I pick this beauty up last spring and been daily driving for the most part luckily I live less than a ten minute drive from work. I have a few things I need to do right off the bat and I have some long term goals and ideas I want do . So first thing is to just getting it running decent Im having a fuel issue it's doesn't like to start half the time unless I give a shot of ether I replaced the mechanical fuel pump with a electric pump but I believe the carburetor that it has one too small second it's hitting the intake on the linkage I order a spacer that will fix that issue hopefully this weekend. I recently color match my dash and need to finish putting it back together hooking up the climate controls and a couple of gauges fuel,temp the switch for the back tailgate, a windshield wiper motor and switch ( if anyone knows of a motor that could be used please let me know) seeing how it's only 2wd and living in Maine this winter I'm not going to drive it I want to drop it 4 or 5 inches and hopefully swap out the tranny for a automatic and clean up under the hood paint the block clean up the wiring .
Very nice! I suggest creating unique threads under the most appropriate Tech Forum headings for best response. For instance your starting issue could be addressed in a unique thread under the GAS ENGINE TECH section along with well focused pictures of your carb etc. etc. Then take a similar approach for any other non-related queries you might have.
