N NONYAMT Member May 25, 2011 #1 Where should the points be set on the 152?should I get rid of the carb vacuum and run it right off the manifold?thanx
Scoutboy74 Moderator May 25, 2011 #2 Depends on which distributor you have. We need to make proper id. Picture please.
Michael Mayben IHPA Tech Moderator - Retired & No Longer Online May 28, 2011 #5 Virtually every question/issue you have has already been discussed in other threads in sub-forums around here in the last three years. Take much time to review these threads and you will find pictures and suggestions throughout.
