1badscout1
I have a 1961 s80 with a stock 152 engine. I also have a locked up 1978 196 engine on my shop floor. Guessing by the bearing material in the oil filter the 196 has spun a bearing. My 152 needs to be pulled out and freshened up. Can I use the 196 entire top end on the 152? I am hoping that by using the 196 top end that I would gain some power due to the larger valves and better flowing head. Has anyone done this? I am concerned about piston to valve clearance? Cooling system differences? Oiling system differences to the rocker levers? Thanks in advance for info!
