1badscout1
I have a 1961 s80 with a stock 152 engine. I also have a locked up 1978 196 engine on my shop floor. Guessing by the bearing material in the oil filter the 196 has spun a bearing. My 152 needs to be pulled out and freshened up. Can I use the 196 entire top end on the 152? I am hoping that by using the 196 top end that I would gain some power due to the larger valves and better flowing head. Has anyone done this? I am concerned about piston to valve clearance? Cooling system differences? Oiling system differences to the rocker levers? Thanks in advance for info!
the middle fingers are to the previous owner!
threadjack over.
) I am currently replacing most of the gaskets on the 304e that I drug home. That way at least half of the gaskets on it might not leak!
drop the TBI 5.7 into the plow rig since I already have a engine and a wiring harness that I built. But those parts are set aside to put into my 1970 fj40 landcruiser. I am anxious to fire the engine off. It has a big block TBI, pro topline cylinder heads (suppose to outflow vortec heads), hydraulic roller camshaft (biggest one I could fit and still keep it fuel injected) hypereutectic pistons (about 9.5 compression) and a GM goodwrench 4 bolt main 1 piece rear main seal block. I am estimating it should put out 375 hp and have a decent amount of torque.
