Winch Plate Mount Holes
Aubrey
Is there a winch plate that matches up to a Scout II’s front bumper mounting bolts? I realize that would only have two bolts in it, but I’m looking for one that has the same width. Then I would just need a section of square tube on the front of the frame for the other two bolts. – thanks
Yep, I saw that one. I was just curious if someone made one that matched up to the bumper width. And now that I think about it, it might even need to be slightly raised in the middle for the winch bolts to fit between the plate and the frame.
Jeff, you wouldn't happen to have dimensions on the whole thing would you? It's width, depth, the width of each of those mounting holes? Also, it is for a flat mount but is there room under it for bolts to the winch? Having if flat flush mounted wouldn't allow room for a bolt up to the winch itself.
Feel free to call aubrey as we'll be glad to pull one off the shelf and get the measurements you are requesting.
