Whistling/Chirping IH V8? Air Pump Rails Port Plugs
Have you removed the air pump rails and put plugs into the heads then hear whistling and/or chirping under acceleration? Very very annoying! Your plugs are incorrect.
The proper plug is a unique configuration. It has to be correct or you will damage threads and the noises May persist. The IH plug is no longer made until now.
I will be having these plugs turned on a cnc lathe as an exact reproduction of IH's part. You can make plugs yourself or go with what you know will work!
Plugs will be $10/each. Yeah, not cheap but see how long it takes you to make your own plugs that May damage your heads and not solve the problem.
Thanks, dan
Just a reminder...this website is the private property of IH Parts America. If you wish to market a product to the binder community via this website, you'll need to contact Jeff in order to discuss particulars.
