Howdy,
'75 scout II 345v8 auto trans.
I recently rebuilt my Holley 2210 carb. The thing whistles at mid range RPMs. Internet search (including here) state likely causes as, #1 bad gasket at the manifold, #2 internal leak from bad gasket in the carb.
I replaced the manifold gasket, I completely tore the carb down again, inspected all of the old gaskets (all in perfectly fine shape), replaced them with new gaskets, made sure everything was together right, and reinstalled it on the engine (345). Still whistles, exactly the same.
Any body ever solve this puzzle? I can live with it, but it sure sounds wrong. Truck runs great, no issue with performance. I have triple checked for vacuum leaks, sprayed starting fluid around it while running, sprayed it down in wd-40 while running, nothing.
Losing my mind. Any thoughts would be appreciated.
Nick
Nick
