Tincture77
After installing a rebuilt alternator on my 73 t'all 1110 392 2wd, I took it out on a test drive to log data for my recently installed afi fuel injection. The battery was reading 14 volts at idle from my voltmeter, so the alternator was working. After about 10 minutes into the test drive upon hard acceleration, the starter engauged and would not turn off (even with the key out of the ignition switch). One of the wires going to the negative terminal on the ignition coil was red hot. After frantically searching for something to disconnect the battery, we got it disconnected and let her cool down. What happened? Could I have connected the two wires that go on the slot connectors on the bottom of the alternator incorrectly causing this?
