Drew Merrick
The weekend started for me at the exceptional IHSTO meeting conducted over at one of the roth's main compounds. It was a damn good meeting with some old and new friends and a diversity of IH iron second only to the Binder Bee. Thanks Mike and ken.
After the meeting Mike mayben brought his high profile mobile IH engineering lab over to my place for a couple of days. I let him get to sleep after a good bit of jawin on Thursday night but got him to work early Friday morn after some pancakes and scottish eggs. Something very new to him!
Friday:
First thing on the list was to start the Travelall up and evaluate my rebuild. The battery was nearly dead so I had to pull the suburban into the field and give it a bit of a jump. No the suburban will not get a "official IH recovery vehicle" sticker
that sticker will go on the john deere mower who had to give the Travelall a jump start after we set the dwell
Along with the dead #8 cylinder and poorly set timing there was quite a bit of lifter noise. We pulled the cover on the even side head and Mike pointed out that one of the rods for the #8 cylinder was missing. "well hell, that explains the loss of compression, better git yurself a flashlight and a magnet and get to fishen". I found the broken rod nestled nicely in the valley floor. We replaced it with a curiously shorter rod from the set off the 152 to further diagnose the oiling system. I used a vice grip to compress the rocker arm.
Once the Travelall was firing on all 8 cylinders and I got enough cardboard to build a mansion for a downtown transient, I threw the cardboard under the t-all (driveway is being resurfaced on Monday and oil is a no no
), we started it up and observed the oil flow. The reason for the broken rod was pointed out by Mike. Although there was some flow to the back rockers it was hardly enough to keep a valve from sticking. We made a plan to rebuild the rocker assembly using the shaft from the 152.
After we got all 8 pistons pumping air Mike showed me the proper way to set dwell and adjust the mixture screws. I added some oil and amazingly the lifters stopped chattering (all but one on the other side). I added some brake fluid to the master cylinder and I had brakes again... The master cyl needs to be replaced so the brakes are intermittent. But I am crazy enough to take it out on a test run.
While I was taking care of the kids and getting dinner ready Mike looked the 152 over and pulled my cam out. The prognosis isn't good. The 152's main crank is scored and might not even be fixable with a 10 grind. The cam is ultra screwed. There are hardly any lobes on the last three and the there is one lobe that is completely gone. There is so much evidence of bad dirty oil over many many years.
I threw a t-bone down on mikes plate (he was more familiar with that than a scottish egg) and made him eat with the boys. My kids have all taken quite a shine on him and they just wanted to hang out in his mobile tech station.
Saturday I had the kids full time as my wife had to spend the day at a high profile baby shower. My one day to work on vehicles was now over. Greg's son Mike showed up with his truck and mayben and him hit it hard with some specialized tuning. I didn't get to hang out that much with them but I do know that truck sounded about perfect as it drove out the driveway.
Mike stayed on and fixed up monte's carb and did some schematical diagnosis on the Travelall. Mike even learned a few new things, like, 1967 Travelall doesn't use a resistor wire or a balast resistor and the coil only has one wire.
well that's it for the weekend report. It was a good weekend, got alot done, the Travelall is running but needs a bit more work for road worthiness and the Scout 80 had a minor motor setback.
Friday:
