Wanted
Going on Scout 80, with a Scout 2 front end. When you say; Scout 5, do you mean; 5 hole Scout lug pattern?
Yes 5 x 5.5 is the hole pattern im not sure if they fit Scout 2 ,I dont think they do.im in oregon so shipping could be an issue im not sure where you are.
going on Scout 80, with a Scout 2 front end. When you say; Scout 5, do you mean; 5 hole Scout lug pattern?
There are different bolt patterns for the 5 lug wheels.
5 bolts x 5-1/2" (bolt)pattern = as far as I know, every Scout model(80, 800, and II) along with most every Ford f-150/Bronco from probably the 60's through late 90's, and maybe some of the 70's heeps too, used this 5 lug by 5-1/2" bolt pattern
there's also the:
5 x 5" = used on some cheby and some heeps
those are the more popular bolt patterns for the 5 lug rims. I think there maybe other bolt patterns for 5 lugs, but don't remember
yes 5 x 5.5 is the hole pattern im not sure if they fit Scout 2 ,I dont think they do.im in oregon so shipping could be an issue im not sure where you are.
It sounds like they will fit, rear end is a Scout 80 and they fit on the front. We are going to be in klamath falls Sunday and Monday.
yes 5 x 5.5 bolt pattern will fit a Scout II. And will fit Scout. 80/800.
Only way for that bolt pattern not fit, is if a previous owner swapped axles or did some other po virus crap.
